Have a LOOK at this Document about assembling & Configuring your LFP Cells.
This document was posted to the forum by Amy from Shenzhen Luyuan and written by Steve S. It was meant to be posted as a resource. Below is her description of the resource: Dear all friends in the forum, This file in the attachment was...
diysolarforum.com
24V System requires 8 Cells to make a Straight Series Pack.
Cells can be put in Parallel within a Pack to double the Amp Hours.
-> This IS NOT SUGGESTED with Unmatched & Unbinned cells. They WILL deviate a lot between each other.
--- Cells that are Paralleled, appear as One Cell to the BMS System, therefore it cannot manage each individual cell. Matched & Batched cells are used in Parallel (think EV's etc) which are matching for Internal Resistance & Impedance throughout their entire operating range, so they all function identically. Matched & Batched cells typically cost 20-50% than Bulk Commodity Cells used for ESS System. See the Link to the Article in my Signature, as well.
Setting Battey Packs in Parallel IE 2x24V/200AH will still provide you 400AH but will also be more Fault Tolerant as well it will share the Charge/Discharge loads on the system and if one shuts down for any reason the other keeps running.
Each Pack will require an 8S BMS (MAX 200A Discharge & 100A Charge capable), one Fuse (not greater than 200A).
Each Pack should be wired to a Common DC Bus using (=)(-) Busbars rated for 300A.
Each pack to BusBar and Busbar to Inverter should use the Same Gauge Cabling. !! Oversizing Batt Wires is a Good Idea as 1) you can future proof a bit but also 2) to reduce resistance and voltage drop. Besides Copper is frightfully expensive, so you only want to buy it once.
Myself, I run 24V with 1190AH of LFP & 856AH of Heavy Lead. All my Battery Wires are 4/0 gauge (120 mm2) from Batt terminals through to Inverter/Charger. They still warm up when taking more than 100A charge but nothing serious. I started my Solar Build based on a 2000W Inverter and used 2/0 Gauge wires but when I upgraded to 4000W I also had to update the wiring to 4/0 and OUCH that stung a bit.
Hope it helps, Good Luck and peruse the links in my Signature.
