Damil 1776
- Jul 12, 2022
- 18
Not sure if it matters, I searched and did not see a post about it. I have a 300ah lead acid battery bank, when running the cables from the charge controller, should I connect the + and - to the same battery or connect + to one battery and - to the farthest battery, or does it even matter? And also does it matter if my inverter connections are on the same battery post as the charge connection
