I have a 24 volt system that consist of 12 battle born 12 volt batteries. They are wired 2 in series and then 6 in parallele. For some reason, one battery in each series always discharges faster than the other. In other words, as batteries discharge, one batter in a series will be at 12.5 volts and the other will show 11.5 volts. This is consistent across the paraellel string. Thinking it was battery issue, I took the system down, recharged all batters to full and then repositioned all batteries putting the ones that stayed at a higher charge rate together and the ones that were at lower charge rate together. Still then same issue. One side of each series was still on a regular basis discharging faster than the other. I don.t understand why one side of a series always depletes faster than the other. And even when I move batteries around the same things happen even with different battery locations.
