I have to agree that the utilities are all big complainers. A few years ago, my home town got into this huge "Save Water" campaign. The hit us with limits for lawn watering, gave incentives for low flow faucets and toilets, and even had a program to help change out landscaping for reduced water use. So what ended up happening? The water consumption in the valley dropped over 40%. The program was a huge success. Sounds good, right? Well, the water company was not happy. Their revenue dropped by that 40%. So they not only raised our cost per gallon, they also added a few fixed charges to everyone. The end result, I cut my water use well over 20%, but ended up paying a little more on my water bill. If you cut 30% is was about a break even, and those who did cut 40% are still saving, but just a little.
I see the same thing going on with electricity. The less we buy from them, the more they are going to charge for it. My math on the payoff of my initial solar install got thrown out the window. I used to have a tiered rate with tier 1 at just $0.12 per KWH. With the amount of solar I installed, I figured I would stay completely in that tier 1 on all but the worst month of clouds and my A/C running. Using that figure, my system would have paid off in 6 years. But no, all new solar installs get forced to the time of use rate. And the cheapest rate starts at $0.17 per KWH. So even if I only used power at the cheapest time of day, it is at 42% more expensive per KWH. Then when the sun is going down, it jumps to $0.43 per KWH. Even if I am using very little power. That is a a 258% increase over my old Tier 1 rate. So my payoff is more like 10 years instead of 6.
When you go by their math, the higher electric rate actually made my system worth that much more. This is the B.S. the solar lease people like to use. As the electric rate goes up, you are saving more money. NOPE. It does not work like that. Had I not put in the solar, I would still be on the old tiered rate schedule. Of course, that was a grandfathered rate plan. If I ripped out the solar, and went back to a tiered plan, they jacked the rates there s well. The cheapest tiered rate 1 is now up to $0.26 per KWH. OUCH!
Now if you want to use gravity energy storage, GO BIG!!
The city's municipal utility is studying the potential of using the dam as a giant pumped hydropower plant run by renewables.
www.utilitydive.com
The idea is quite simple. Install solar powered pumps to push water back up into Lake Meade when the sun is shining, and then letting it generate through the existing dam. I like it. 3 billion does seem a bit pricey though. You do need some serious pumps to push water UP over 700 feet. And it will take a lot of solar to power that. But 3 BILLION, that sound like the $40,000 military hammer.
