SebKuzminsky
Hi there, i'm new to the home power game. I just got a 10 kW grid-tied PV array installed, all Enphase gear with micro inverters. I've had fun charging my EV using surplus power from the PV system: https://github.com/SebKuzminsky/solar-evse/
I have a couple of kWh of second-hand batteries (48V nominal) with a matching charger, and i'm thinking of building a system to do this:
All the inverters i'm familiar with are pretty dumb:
In the closed-source/proprietary space, the Enphase IQ8X-BAT looks like it does approximately what i want, though i'm not sure if it's controllable from the outside like i want.
Does the thing i want make sense, or am i thinking about this problem wrong?
Does such a thing exist?
Thanks all!
- When the PV array is producing: use surplus energy to charge the batteries up to 80% SoC or so. When the batteries are "full", export any surplus energy to the grid. I'll modulate the charger current like i modulate the EVSE in the project above to avoid importing power from the grid to charge the batteries. The charger is a DeltaQ ICL 1500, the charge current is controlled over CAN.
- When the PV array is not producing: turn on an inverter to supply the house from the batteries. Draw the batteries down to 20% SoC or so, then turn the inverter off and import whatever power the house needs from the grid.
- You turn them on and they just supply whatever the load asks for, until they overload and shut down, or until the battery drains and they shut down.
- They don't want to be connected to an existing AC grid.
Thanks all!
