Is there a way to monitor your batteries from your phone when you're away from home??
Sounds like you need a smart shunt that measures amps and voltage.Monitoring battery capacity would be ideal. I cannot code and neither my CC nor inverter have built in monitoring that I could web-enable.
Like your option, but for a lot less then the $400....you can do this....I do it for my Midnite SCC.Sounds like you need a smart shunt that measures amps and voltage.
You'll then need to connect this to a PC or Cerbo https://www.amazon.com/dp/B0851KGF57?ref_=cm_sw_r_cp_ud_dp_KZ5ET4TRE7J51BDNN7Q9
$100 Victron smart shunt connected Bluetooth to an old phone and then have a $35 WYZE camera pointed at the phone where you can view through the WYZE app for free everywhere there is wifi.... all for under $150 and easy to setup.
Easy peasy!Thank you for all of the quick and thoughtful responses! I think I might just aim one of those WYZE cameras at our current shunt monitor display. I'll leave the display on the "capacity" screen and aim the camera right at it. I didn't know about those little cameras, but they seem perfect... and cheap!! $35? How do they do that?
Thank You Thank You!!!
Here's a post outlining the RPi solution. https://panbo.com/victrons-venus-os-on-a-raspberry-pi-install-and-configuration/If you just wish to monitor your battery remotely (voltage, state of charge, charge/discharge current, etc.) then using a Victron SmartShunt and a Raspberry Pi (RPi) running Victron's Venus OS would be a "cheaper" option. You need a cable to connect the SmartShunt to the RPi. You need a cheap buck converter to power the RPi off of a 12V battery. The RPi can connect to local WiFi to send the battery data to Victron's VRM website. You can access your data simply by visiting the VRM website. Maybe about $250 depending on how much an RPi is going for these days.
I don't use equipment that uses the cloud for data privacy reasonsYeah. My thinking is the easiest way for a Newbie to do it.
I run a mini-pc and remote into that and just look at my EPEVER that way. Other guys are just using the Pi in place of the PC.
Make sure you figure out how much of your internet data it will use broadcasting video 24/7.I didn't know about those little cameras, but they seem perfect... and cheap!!
Ha ha. Enable FTP so you get footage of the fire.I don't use equipment that uses the cloud for data privacy reasons
In the earlier days - I used a camera pointing to my EPEVER - to monitor on desktop. I have VPN on my desktop for remote viewing from my phone.
But it occurs to me that even cheaper cameras have cloud store/access - you might find a way to set one up.
I not only use cameras for monitor, but to record to see what happened over the last several days if necessary. Here's an example of one of my cameras - that monitor output from the inverters.... Only using 1 inverter right now - 2nd one needed at full summer.
For the WYZE Cam V3, it appears that SD video will use between 1.4-2.8 GB/day and HD video will use 5.8-10 GB/day to broadcast 24hrs continuous. You can also turn the camera on/off from your phone and/or schedule times that it will turn on/off automatically.Make sure you figure out how much of your internet data it will use broadcasting video 24/7.
The cameras also usually only transmit when you are connected to it unless you pay for cloud storage.For the WYZE Cam V3, it appears that SD video will use between 1.4-2.8 GB/day and HD video will use 5.8-10 GB/day to broadcast 24hrs continuous. You can also turn the camera on/off from your phone and/or schedule times that it will turn on/off automatically.
