Hello, first time post and have some basic battery questions I can't seem to find answers for from a general search. I had2 100w panels on the van with 1 100ah 12v LiFePo SOK battery. Then I decided to get another battery but SOK was sold out of the same battery so I bought a LiFePo battery from Renogy and hooked them up in parallel (keeps the voltage the same at 12v).
Is this okay? I saw the Renogy manual said that you shouldn't mix battery brands even if its the same chemistry, is this right?
Also, what's an easy way of finding out if both batteries are charging? Do they both charge together or one first and then the other? The Renogy charge controller (20A MPPT) says the battery is at 100% but it said that when I had just the one charging. Is it smart enough to figure out I added another battery? Any easy way to make sure everything is wired correctly and that both are being used?
I did get a battery monitor wired up but I figured I'd just let everything charge completely to calibrate it rather than drain them completely.
Thanking you in advance for any good advice and answers the community provides!
