Hi Will, thought I’d ask what you guys think...out of this list which is the best to use in my off grid camper (4x):
1) SOK Battery LiFePO4 Deep Cycle Rechargeable Lithium Battery 12V 206ah Built-in BMS,Low Temperature Disconnect.
2) Ninthcit 3.2V 230AH LiFePO4 Deep Cycle Battery Cells with Iron Phosphate, Grade A Replacement Automotive Lithium Motorcycle Batteries with QR Code, Perfect for Boat, Marine, Golf Cart, Camper(4PCS)
3) Ampere Time 12V 300Ah Lithium LiFePO4 Battery, Built-in 200A BMS, Max 2560W Power Output, Easy Installation, 4000+ Deep Cycles, FCC&UL Certificates, 10-Year Lifetime,
4) LOSSIGY 12 Volt 300AH Deep Cycle Lithium Ion Rechargeable Battery, The Perfect Replacement for Solar Wind system, RV, Marine Off-Gird Battery, Built in 200A BMS, 4000-7000 Cycles
Many tks!
