I am in the early planning stages of planning a 19kW solar (roughly 115m^2 area) with 20-60kWh LiFePO4 UL rated batteries (likely rack mount). I tend to go from "it will work with duct tape" to "over engineered with titanum screws" quickly so asking for some feedback.
* Minnesota St. Paul area
* I want the battery because frequent power outages/surges and maybe get some RoI by switching to time of day billing
* During June and July I have used ~40kWh a day average (according to my bill).
* I have -22F mini splits and backup restive heaters but don't have any usage data for that yet, I expect it to be more than summer. (100% electric)
* Was hoping I could get 40kWh+ in winter, though doing some research at 4m^2 per kWh that is closer to 28kWh, so batteries for cheap(er) grid electricity.
* Xcel Energy (not sure it matters but thought I would mention it)
I started by asking the housing inspector and the first concern that came up was where to put batteries and fire saftey. I have an unfinished utility room with a water heater, washer, and drier.
* Initnally I was just going to finish what I could with Firecode X sheetrock then a fire would need to go ~10ft before it got to the other side of the room with exposed stuff that I can't easily finish (water/drain pipes going everywhere).
* Next I thought I could make a few 5'x3' closets lined with Firecode X sheetrock and put on metal doors. I would need ventilation into the house as there would be a lot of heat buildup I would like to use anyhow.
Then I found the Minnesota fire code things got more difficult over 20kWh because if I am reading it right I need fire suppression system and exterior veltlation for anything betwen 20kWh and 600kWh. There seems to be hydrogen/gas concern for lithum batteries which I thought was a weird concern for normal operation. Meanwhile I have 150kWh+ of NCA batteries sitting in my garage but I digress....
* So then I thought at that point it may not be much more money to build a 8x10 shed, 6in or 8in wood walls (I think metal would be overkill), Firecode X sheetrock, insulated, no windows, mini split, metal self closing door, 5ft+ from the house (I believe the fire code), cement slab, metal roof, and run 2x 3/0 AWG Aliminum circuits (200A) about ~50ft from my main panel (so basically all house grid goes through this shed). I will then put the MID, inverters, batteries, and such in this shed and some way to byapss it all if a MID fails. Some side positives is it moves the inverter noise out and I don't lose any starge space in the house. If I go with EG4 (TBD) I would also need to run the solar DC down my roof and to the shed so that could be 100ft from the furthurest panel too (though at 400V+ 100ft may not be a big deal vs 240V).
so... did I go too far or not far enough? I am planning to consult the fire marshal and would like to get my options/questions in order before making an appointment. After I figure out the details where it will go work with Xcel Energy and open the proper permits to do the work (whatever we come up with).
NOTE: I haven't got brand/model details down, this is just a general saftely question for any lithium battery based system. I would like whole house backup which is why I am leaning toward a MID and 10kW - 48kW worth of battery power generation.
