chadmichael
- Feb 26, 2022
- 51
I have a Big Battery 170 Ah 12v OWL, spec sheet here.
Here are salient points from my battery specs and system build...
1) Specs say this has a built in 300 A safety fuse. As I've seen on some tear down videos, this fuse is behind the negative terminal. I understand this to be a sort of last resort safety protection against a very high draw (short circuit? other?)
2) Specs for the BMS say Max Charge and Continuous Discharge are both 175 Amps.
3) Specs say Max Peak Discharge 350A (over 6 seconds)
4) Following Will P's 400 Watt mobile build recipe, we have a 200A fuse bolted on to the battery's positive terminal (sized according to my inverter )
QUESTIONS
1) Why do I need the 200 A bolt on fuse since the battery's own built in fuse is there? What scenario does this fuse protect against?
2) How does the battery every discharge at 350 A for 6 seconds when both the bolt on fuse and the internal fuse (300A) would seem to positioned to cut off the current at a much lower level?
3) What scenario is the internal 300 A fuse built to protect against? And why is it on the negative when we put the external fuse on the positive terminal?
QUESTIONS
