cristipurdel
- Nov 30, 2019
- 13
I am looking to add a grid tie battery system to fully utilize my solar production.
I have a couple of 80W sunpower panels hanged on my balcony, and daily I can produce a maximum of 0.6kWh during summer by feeding around 130W back into the grid via a grid tie inverter.
What I want is to find a grid-tie battery system which should store the 0.6 kWh battery during sunlight but output a constant power of around 100W which should cover my minimum consumption (vampire draw + etc.)
Basically should be some sort of "legion solar" type but without the hustle of playing around with the mains/breaker box cables.
I guess I would need a charge controller but I have not seen many videos on how to limit the power output and to oversize the battery in order to increase also its lifespan.
It would be really helpful if I could see a video detailing this or some diagrams of sort.
The end goal would be the following scenario.
6x80W panels producing a maximum of 400W.
The panels should be connected to a charge controller / hybrid inverter which gives:
100W back to the grid constant to cover my minimum consumption (or maximum of 100W without feeding the batteries)
0-300W to the battery system. When the sun is not shining then the batteries take over and discharge up to a defined % (e.g. 30 SoC). The batteries should be connected to a grid tie inverter (I already have one of 260-300W max ).
