NICE!!! That’s exactly what I’m looking for. Unfortunately, I got greedy and bought 280ah cells and they are too big to fit in this case. Hopefully I can find one slightly larger or I can find the connectors to make my own. I really don’t want to drop down to smaller cells.Here’s some options on Aliexpress but with the upcoming holiday it might take a while. ?
US $46.00 | GTK lithium battery box 12V 24V 48V 100ah 120ah 150ah li ion lifepo4 LTO battery ABS+PC battery empty case
41.4US $ 10% OFF|Gtk Lithium Battery Box 12v 24v 48v 100ah 120ah 150ah Li Ion Lifepo4 Lto Battery Abs+pc Battery Empty Case - Battery Storage Boxes - AliExpress
Smarter Shopping, Better Living! Aliexpress.coms.click.aliexpress.com
Interesting. This just might work. I'll pick up a pair and check them out.Since you work with metal and can build your own box I may suggest something like this. The only thing is you would need to mount them on something non conductive. Perhaps you could make a HDPE plastic lid or do what I do and use thick plexiglass
https://www.homedepot.com/p/1-0-to-...onductor-Mount-2-Pack-ADR11-21-B2-5/100172941
wow; that is tight. with the eve 280ah cells in a 4S configuration you'll be right at 12" wide. if not mounting the BMS above the batteries maybe along the horz side then ?.I have limited space in my battery compartment so I'm trying to keep the case as small as possible. I have a two section compartment for two batteries and one is smaller than the other. If I can keep the battery below 12" inches in length, I can install two. So that's what I'm shooting for but it will mean mounting the BMS above the cells. I plan to 3D print a mount for the BMS that separates it from the cells. It's going to be tight but again, I'm not worried about heat because the battery will suffer very little load.
I plan to mount the BMS above the cells, but I think mounting it on the side is possible as well. I have the dimension for the BMS and it looks like either way is possible. I just need to get them in my hands so I can play with different configurations. The max width of my RV's battery compartment is 8" inches.wow; that is tight. with the eve 280ah cells in a 4S configuration you'll be right at 12" wide. if not mounting the BMS above the batteries maybe along the horz side then ?.
