sunshine_eggo
Victron's little biatch
The smart shunt has nothing to do with charging. The parameters are for when the shunt determines when it synchronizes and displays 100%.
Current dropping to "almost nothing" at 13.6V may or may not be an indication of a full charge. Imbalanced batteries are not fully charged, but they may behave as you've observed.
I'm still disturbed by that level of drop. It seems excessive. Unless you can verify the battery capacity with a discharge test, I would still recommend holding the batteries at 13.8V for 24 hours and see if the drop behavior changes. I understand this may not be an option, but that doesn't change my preference. If you can leave them at 13.6V for 24 hours, that might help too.
