I have two 12 volts lithium batteries (Redondo)
Being charged by 1000 watt solar array via a 60 amp mppt solar charge controller (powmr)
For some reason yesterday the whole system shut down
I checked the battery voltage at the positive and negative terminals of the lithium battery and I get a total of 20 volts in series
But when I connected to the solar charge controller suddenly the same battery terminals on the lithium batteries show me two to three volts?
I can't seem to figure out why it would be 20 volts when not connected to the solar charge controller and suddenly two to three volts when connected to the mppt
In between volts certainly will not turn the sword charge controller on so I'm stuck,
Same thing happened if I connected to the inverter suddenly the voltage will drop from 20 volts down to 2volts
I'm stuck, any idea??
