Has anyone noticed their LiFePO4 voltage acting like in the attached image? This is while using about 4.5kW from my 16kWh bank, using Ampinvt 5000/15000w pure sine wave inverter. The voltage range is so small that I can't really see this pattern using any other method. The graph below is produced by my Victron MPPT 250/100 solar charge controller.
The system has been great and everything seems to be working fine - just thought the pattern was a little odd
edit: one full cycle (one peak to one low, back to one peak) is about 2.5 minutes...
