John Glowacki
- May 11, 2020
- 10
2 Battle Born 100ar 12 volt batteries in paralell.
Victron Multiplus Compact 12/2000/80-50 120v inverter charger. It is supposed to provide 2000watts continuous and 3000watts peak.
VE Bus Smart Dongle.
2/0awg copper cable maybe 8 feet long.
This set-up is in our fifth wheel travel trailer. If I am running the air conditioning while connected to shore power, the VE Bus Smart Dongle shows about 1400watts AC out. If the shore power goes down, I lose ALL power, including 12V. 12V comes back after the batteries reset. Battle Born tells me that there must be an instant over current draw, or voltage drop, and the batteries shot down in fail safe mode. The same happens if I try and start the AC on inverter mode. I'm not sure if I have a soft start installed on AC unit, but I can easily start this AC using my Yamaha 2400watt inverter generator.
What am I missing here? I did not build this system to run the RV AC, but I would think it should. Does this seem right?
