evilroy New Member Joined Jan 27, 2021 Messages 55 Nov 15, 2021 #1 Battleborn 12 volt 100 ah battery, used 0.22 Kwh in 24 hours = how many ah were used? I come up with 18.33 ah is this correct?
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Nov 15, 2021 #2 evilroy said: Battleborn 12 volt 100 ah battery, used 0.22 Kwh in 24 hours = how many ah were used? I come up with 18.33 ah is this correct? Click to expand... 100 amp hours * 12.8 nominal volts = 1280 watt hours. 1280 watt hours / 220 watt hours = 5.818181818 100 amp hours / 5.818181818 = 17.187500001 amp hours
T time2roll Solar Wizard Joined Mar 20, 2021 Messages 5,610 Location SoCal Nov 15, 2021 #3 I believe both could be correct depending on the battery voltage.
John Frum Tell me your problems Joined Nov 30, 2019 Messages 15,234 Nov 15, 2021 #4 time2roll said: I believe both could be correct depending on the battery voltage. Click to expand... 12.8 volts * $ amp hours is the value that corresponds to the total capacity of the battery in watt hours. I would be surprised if you don't know this.
evilroy New Member Joined Jan 27, 2021 Messages 55 Nov 15, 2021 #5 This jives then, battery has used 18.33 ah of 100 ah yet is showing it has used 60% of capacity or 13.16 volts down from 14.1 in 24 hours. Last edited: Nov 15, 2021
R richard cabesa New Member Joined Mar 16, 2021 Messages 175 Nov 15, 2021 #6 A battery doesn't really USE anything. What is your load and what are you measuring it with?
