Ziggy With It
- Dec 15, 2021
- 35
I'll go down the list.That’s a good size list of loads .
I would skip the micro wave and cooker off grid , or maybe run a small generator for them off grid .
Lights don’t really use any power so you are good there , the tv is ok just turn down the brightness a little bit and it uses a lot less power .
My c pap uses less power and if it dosent you should look into a new unit .
My old unit uses about 55watts if I add more heat it uses more , I don’t use heat on my unit .
My face would freeze to my mask this time of year , and that brings me to the heater, my system would work down to about 30o temp out side , colder then that my heat would run all the time and kill my battery’s .
I would use a buddy heater some time allso but below 20o I can’t get the trailer warm no matter what .
You frig is ok allso , but just the frig bring your system to medium size .
then you have to mount panels on a flat roof witch kills Power production especially this time of year .
If you mounted 6 300 watt panels flat on your roof with 20” hanging off the back they should fit.
The over hang acts like a small porch if the back door is open .
I would use a 24v 2000watt inverter charger with 200 AH worth of battery to start
I have 3 295 watt panels that bring in 750 watts or a little more at noon on a clear perfect day in June for 4 hours +-
this time of year I get half , 400watts with one string but I have 5 strings ?
on a cloudy dark day I get 200 watts on all 5 string and some times I get now power at all
I can probably get away with not using the microwave for a few days. I'm using it for popcorn and heating up a sandwich at the moment but will start doing other stuff like air frying french fries.
My CPAP is provided by the VA, so that's what I get. On the few nights when I've been off grid with it and using the extra special $300 battery it went for about 4-5 hours with the humidifier on and 8 hours with the humidifier off. May have gone more, but I was awake so I really don't know how long it would have lasted. But I guess I don't need the humidifier on if I have heat.
I have absolutely NOOOOO plan to be anywhere near 20o. So far, I've been caught in a freak 33o for a couple of nights and the heater worked fine. But 20o??? Only if I get caught somewhere that I shouldn't be!
I have no idea what "medium size" is.
Okay, so I'm looking at a 24v system and 200 AH to start. I know there are also 48v systems, but, again, I have no idea when or why I would need either.
