I am in the process of doing the first top balance of my new LF280K cells from Amy Wan. I sorted the cells by capacity according to the test results provided by Amy and I've got the 16 highest capacity cells in parallel right now on their way to 3.65V (currently at 3.326V from a starting voltage of 3.282V) using this power supply:
Kungber DC Power Supply Variable, 60V 5A Adjustable Switching Regulated DC Bench Linear Power Supply with 4-Digits. I'm doing it in steps and so I'm on the first charge up to 3.40V on my way to 3.65V.
I've got the cells in a compression fixture with threaded rods and ZUSANSR-315 foam that specs out to give a firmness @ 25% deflection of 13 PSI (Foam Roll, Water-Resistant Closed Cell, 36 in W, 10 ft L, 3/16 in Thick, Black, I found it on Zoro for $132). I fixed the cells with 9 layers of the foam at 25% compression at the cell voltage of 3.282V which is the voltage that I received them at. I tried to get more information about the foam and a deflection curve of what the PSI would be at different deflection percentages but the manufacturer has not responded to my inquiries.
So after I charge the cells up to 3.65V is it okay to decompress the cells and remove them from the fixture so I can reassemble them in a 24V configuration (my inverter is currently 24V with a 48V unit on order), and then put them back into compression with a foam deflection of 25% so I have the 13 PSI at a 100% SOC? Would the cells expand/bloat when decompressed at 100% SOC or does the expansion stop once the charging stops and they are safe to remove from the fixture?
Also, it seems to me that accurate compression of 13 PSI would be more important at the higher SOC as this is when the cells would potentially be at maximum expansion. None of the cells are shipped with compression so it seem they are not worried at all about expansion/bloating/swelling at the voltage they ship the cells at. My cells arrived after almost exactly 3 months from the time that Amy did the testing, gave me the results and shipped the cells. They were at 3.297V when they shipped and they arrived at a voltage range of 3.281V - 3.282V.
I believe I've read that once a cell bloats out there is no returning it back to it's original form and the internal damage has been done. After spending almost $5K on these LiFePO4 cells I really want to make sure I don't do anything that has a permanent negative impact to my packs.
Finally, I did purchase this if l need to draw down the cells after they are top balanced so I can loosen the fixture and reconfigure the cells: 150W 4-Wire Electronic Load Tester 2.4 inch DC Tester APP Electronic Adjustment Constant Load Lithium Battery Capacity Monitor Discharge Charge Power Meter Supply Checker
I'm thinking I can discharge the cells to the voltage that they shipped the cells at, 3.297V and be safe that they don't expand when I remove them from the fixture.
Thank you for any and all advice!
