Server PSU's are generally 12V, but with high amps.
Switches/router PSU's are 40-50V depending on the model, so more suitable for a high current demand with higher voltages like the Riden is capable of.
That TekPower is an easy all-in-one, but at a price. Yes, 60A is great, but you need proper wiring also for these currents. A Riden 18A (or 24A once its available) powered by a 12V server PSU will work as just as fine and is a lot cheaper. Yes, it will take 2-3 times longer, but if you serie-charge the cells first till 1 hits it HVD you don't have to top off that much anymore. And the thinner wires make it much easier to handle / less voltage drop and issues (60A continously requires good cables, crimps and connections)
ATX power supplies: Most of them have a limited 12V line. You don't need massive amps at the 5V rail. And some provide 2 seperate 12V rails, but you need a single (high-amp) rail. I don't see any reason why you would prefer an ATX-style PSU compared to a server PSU. More amps on a single 12V rail and cheaper...
Here is my solution:
Cisco 40V 1300w PS > Riden head unit > Max 40V @ 18A (720w)
That would work fine. And you're able to pull full load of the Riden.
You only need to add a resistor (see the youtube link) to get the Cisco PSU to turn on.
Output will probably something like max 39V, but I'm unsure how to exactly read the Riden datasheet for its voltage drop between input and output.
It will be a nice match, with 18V max output of the Riden and 20A which is the PSU capable off.
Also, if you modify it, the cooling fan of the PSU can also provide cooling for the Riden..
Not sure about the internals, but you might even be able to fit the Riden into the Cisco's case, only rewire the output terminals and you have a solid case/powersupply with decent cooling. (Might be noisy tho)
Q: Can I use a Mean Well LRS 300-48 with my Riden 6018w?
I have a few ebike packs I am playing with, I want to use them with a buck converter on my boat to power electric reels.
Sorry, I am very rusty in my EE, been deep in diapers and now in teen hormones ;-)
Yes, would work, but as with the Cisco, output will be something like 47V max or so. So not suitable to charge a 48V bank, which requires about 51V. But most ebikes are 36V so that will work (but in that case, the Cisco also will do)
You can even power 2x RD6018 with a single Cisco to make a huge dual-output powersupply if you get the bigger versions.
The disadvantage of the LRS300 (LSR350 I think, since you're linking to the 350W specs) is it only provides 7.3A, so with the Riden set to >approx 20V you can't pull the full 18A without overloading. And once the overload is triggered, the PSU will shutdown and not recover.
You're limited to 350W (approx 330W or so I think if you take the Riden's losses and cooling fan and some small margin). So with 36V, you can only pull 330/36 = 9.1A
48V Shutdown and latch off o/o voltage, re-power on to recover
Source:
https://www.meanwell.com/scripts/resource/pdfJS/web/viewer.html?f=LRS-350&pdf=LRS-350-SPEC.PDF
I personally find this annoying, since you will probably (accidentally) push it over its limits, thus shutting down the whole thing.
Repower, reconfigure, reconnect... retry.. going to be a pita
