I'm running 170kWh of batteries with voltage cutoffs. Call me old fashioned, but after setting up every communication protocol out there, I don't think it's worth the headache.
Besides code compliance, is there any real benefit to using closed loop comms?
I think rapid shut down of the entire system is cool, but if there is an issue, each pack has its own set of safety features to remove itself from the system. And if that fails, each pack has a breaker that is DC rated. If multiple parallel strings were dumping current into a failed cell AND the BMS also failed, the breaker would catch it.
In that situation above, having rapid shut down and closed loop communication would not help. You would have to have BMS failure where the fet bank is not able to disconnect the pack from the system. So whether you have closed loop communication or not, the breaker will come in to save the day. Again, this whole situation is extremely rare, But I'm trying to think of everything possible here.
One argument I've heard is that the inverter charger will slow down the charging when the batteries are nearing 100% SOC. That benefit is short lived and most of these packs balance just fine regardless. Not worth the trouble at all. Such a weak argument.
I can't think of anything else. Is there any benefit here besides code compliance?
