wired1
So do you folks know, can I still somehow use the 12 volt inverter with a 24 volt battery pack, or should I return it for a 24 volt inverter? I don't plan on needing more than 2000 surge watts when 2 small refrigerators turn on at the same time...Normal usage will be around 400 watts per hourThat’s really based off the inverter. I only see the battery size.
If you are asking what size inverter to buy, that’s a loaded question based off loads and how long you run them.
