Daddy Tanuki
Emperor Of Solar
fat chance Bro... my wallet always screaming at me and my stupid ideas.Whatever gets the job done without molesting my wallet.
I ended up finding a Mean Well RSP-1000 at a reasonable price on ebay. I think it matches my generator well, v is adjustable to 55v, and can also take DC as an input (127~370v dc), so I can connect directly to solar if I want to tinker with it.No, that's how I'm running mine. I didn't get to the CAN bus, yet. I just turn it on and turn it off. It's not ideal but it works perfect for my needs.
Yes, it would definitely trip. When I wired mine up for 120V it was pulling ~2kW on the AC side.
Post in thread 'DIY 'Chargenectifier'' https://diysolarforum.com/threads/diy-chargenectifier.56329/post-1134200
I ended up finding a Mean Well RSP-1000 ... can also take DC as an input (127~370v dc), so I can connect directly to solar if I want to tinker with it
That’s a nice bench supply and will definitely meet your stated use criteria.How about this:
60V 20A Switching DC Power Supply 1200W - Best Deals on Mastech Variable DC Power Supply
High-quality, stable, and powerful switching DC power supply with 1200W max power. Continuously adjustable voltage and current outputs from 0-60V DC and 0-20A.Buy now! - Guaranteed best price for Mastech Power Supply, regulated variable DC power supply, linear DC power supply and switch mode DC...mastechpowersupply.com
Well, yes, plus or minus the details. And the UI. And the specs. And the prices. And potentially other battery-charger-specific features.All this discussion of the different brands, Mean Well, Chargeverter, Mastech, and others my question is do they all do the same thing the Chargeverter is needed for.
Well, the CV doesn't convert anything to a pure sine wave, all the above and the CV are battery chargers, converting a wide range of power input to DC at a particular voltage with a settable current limit.Take modified or "dirty" power and convert it to "clean" Pure sine wave form?
With this info I should be able to plug my Drok 60v power supply into (example) Craftsman's open frame 6000watt "non-inverter" generator and charge 48v lifepo4 server rack batteries safely?Well, yes, plus or minus the details. And the UI. And the specs. And the prices. And potentially other battery-charger-specific features.
I got my Mean Well for less than 20% of that cost, with free shipping, for essentially the same wattage when you take into account the continuous overload factor. Granted, it's used, but it's built for industrial applications, and has an extremely high MTBF rating.That’s a nice bench supply and will definitely meet your stated use criteria.
I see the screw potentiometer on the front is that how one would adjust the voltage to max 55v?I got my Mean Well for less than 20% of that cost, with free shipping, for essentially the same wattage when you take into account the continuous overload factor. Granted, it's used, but it's built for industrial applications and has an extremely high MTBF rating.
https://www.ebay.com/itm/156818215382
That’s the one, though it may be a (mostly) full turn from min to max, so may not be adjustable by normal humans to the mV. Also readouts and current limiting are missing if you care about those features.I see the screw potentiometer on the front is that how one would adjust the voltage to max 55v?
See no knobs or other adjustment method.
Yes, My DROK looks similar to the mean well in design except mine has two knobs and a readout for volts and amps.That’s the one, though it may be a (mostly) full turn from min to max, so may not be adjustable by normal humans to the mV. Also readouts and current limiting are missing if you care about those features.
I have a DROK with separate displays and multi-turn knobs, and it's horribly inaccurate, especially the ammeter at low currents, prone to boil my FLA batteries dry. I'd replace it with a decent bench supply if it weren't for the sunk costs of the DROK and the low priority of the 'proper' one.Yes, My DROK looks similar to the mean well in design except mine has two knobs and a readout for volts and amps.
Yes. Did you see my response at https://diysolarforum.com/threads/best-48v-ac-dc-charger.102006/post-1394192 ?Did you see my question on would the DROK be able to plug into the Craftsman "non-inverter" generator and export/charge my 48v batteries with pure sine wave voltage?
I don't think that means what you think it means, please revisit your terminology and/or expectations for DC POWER SUPPLIES.Is pure sine wave needed if directly charging the batteries? I assume yes since the electronics (BMS and such) are probably sensitive to Hz coming in.
Not at all.How sensitive are the cells themselves to changing Hz?
I have separate chargers for all the other batteries (types) and the server racks when in use. The Drok was only for the 48v server rack batteries to balance them before putting in service and haven't used since, it just sits unless I buy another battery which I have no plans anytime soon. I also verified what was going into the batteries with the battery software communication (laptop) and a meter.I have a DROK with separate displays and multi-turn knobs, and it's horribly inaccurate, especially the ammeter at low currents, prone to boil my FLA batteries dry. I'd replace it with a decent bench supply if it weren't for the sunk costs of the DROK and the low priority of the 'proper' one.
Not at all.
Maybe. Some devices are built with greater tolerances for bad wave forms and fluctuating voltages/frequency. Try it and let us know.Can I plug the Drok (or any 48-volt charger excluding the CV) into a "non-inverter" generator, will it damage the Drok, or will it charge the batteries just the same by converting to DC?
The cells are being charged with DC, so ac input won't matter.Yes, My DROK looks similar to the mean well in design except mine has two knobs and a readout for volts and amps.
I see where I made a mistake in the question too.The cells are being charged with DC, so ac input won't matter.
I might just try it. I planned to replace with a better unit down the road. I'm always trying to have more than one way to do something. Two generators (one inverter-one non), propane back-up heater if oil furnace goes down, and regular cable with Starlink on hold to name a few.Maybe. Some devices are built with greater tolerances for bad wave forms and fluctuating voltages/frequency. Try it and let us know.
If it's like the one below, it doesn't appear to be very sensitive to input voltage or frequency. I know the Mean Well takes DC input as well.I see where I made a mistake in the question too.
The Drok was what I should have asked being sensitive to the Hz not the battery. I was thinking too far ahead in that damage to the Drok would damage the BMS in the battery but can see I was wrong.
Pretty much the same thing. Worked fine for what I needed and when I bought it was $60 dollars.If it's like the one below, it doesn't appear to be very sensitive to input voltage or frequency. I know the Mean Well takes DC input as well.
Looks like the one I got as well:Pretty much the same thing. Worked fine for what I needed and when I bought it was $60 dollars.
