I'm looking to replace my 100amp gel set up with a lipo . Currently using a ctek dc-dc and a separate mppt (170 watt panel) controller to get the most amps. I run a snowmaster fridge freezer, and will be getting a diesel heater . More solar when my new wedge camper is built. Heater draws 9 amps with glow plug on and .5 running, fridge anywhere from 2.5 to 7.5. not much load for the system. I like the option of a blue tooth BMS. I'm not to concerned with monitoring the whole system, its just a camping set up. Do you think 280 is over kill ( buy once cry once) or would 180 be enough? I'm a lineman and work with high voltage , but playing with the solar has been fun. Thanks Bill
