curtismold
- Jun 17, 2021
- 11
Ok here is what we got....
48v 310ah DALY smart BMS. (will prob double or more battery size.)
2000 watts solar... MPPT is acting up.
12v to 48V charger 40amps...
Running on a 9kw powerjacked inverter.
It is in a 55foot Motor Yatch.
Got Split phase 120/240 at 50 amps, and a 20kva generator with a 80amp breaker.
I do have several appliances that need both legs of the split phase. Gota have 220.
It is a very manual setup at this time to switch from source to source.
Time to upgrade Inverter and get some ability to charge from shore/generator power. Faster selection of power source.....
So what inverter/charger with shall I go with ????????
Victron???? Growatt????
What would you do??????
