I built a 12 volt generator box, and need connectors that can handle PV in (max 100 volts, 40 amps), DC charge in (30 amps) a smaller inverter connection (~50 amps) and large inverter (~200a).
I ordered some XT60 connectors, and was not impressed by the size, or feel. They seem like a good product where light weight is needed, but they don't feel "solid" in my hand, and I cant easily crimp one in the field without soldering. I have not tried XT90's yet, but the pictures don't make them look much larger, and the field soldering issue remains.
I use MC4 connectors on my PV array, my issue with them is polarization, and the surface mounts are ugly. If it's the best option, I wouldn't mind using them for my solar input though.
I like the feel, and standardization of SAE connectors, but from my understanding, they aren't rated for more than 20-30 continuous amps. SAE would have my vote if they made a higher rated connector. If anyone knows of any SAE connectors that are capable of more amperage I would love to know.
What are people's thoughts on Anderson power poles? I've never used, or even seen one before. What sizes do you guys and gals use for your projects? Any recommendations for other brands or styles that work well for high loads are more than welcome too, some of the circular Aviation connectors caught my eye, but without a direct recommendation from somebody who's used them with good results, they're a little too pricey.
Thanks in advance!
Thanks in advance!
