Ampster
Renewable Energy Hobbyist
I baby my batteries because the economics of solar are improved if I can divide the battery cost by 2500 cycles rater than 1000 cycle. It is simple math, not a drag race.
I don't use a generator. I sized my pack so I had reserves. The benefit mathematically was that reserve also served to increase the life of my pack. My point was that 2500 cycles is a lower overall cost per kWh than 1000 cycles. Simple math.it’s not a drag race , keeping your refrigerator or water pump on without resorting to a generator is ideal and you want to use a gas generator to save cycles on your batteries..
I have two Coulomb counters and they drift apart unless reset. I use voltage of 3.45 per cell at the top and a combination of voltage and SOC at the bottom. My LVD is 3.1 volts per cell but my inverter does not wait for solar if I gets to 50%. It begins charging from the grid.Discharge until it indicates 10% - that's your low voltage threshold.
Charge until it indicates 90% -
I believe you can get at least full 2500 cycles or 5000 half cycles from Grade B cells with a reasonable use pattern. Perhaps there are differences of opinion about what "reasonable" is? I do not have long term data to prove my assumption but having a six year old EV with less than 10% degradation gives me hope.You won't go from 1000 cycles with a reasonable use pattern to 2.5 times as many with babying them.
You are confirming my point. You don't need to baby your batteries and try to squeeze every last cycle to get 2,500 cycles. This is 7 years of reasonable use to get to 80% capacity.I believe you can get at least full 2500 cycles or 5000 half cycles from Grade B cells with a reasonable use pattern. Perhaps there are differences of opinion about what "reasonable" is? I do not have long term data to prove my assumption but having a six year old EV with less than 10% degradation gives me hope.
Yes, in one of my iterations I used seven year old Nissan Leaf modules that still had 80% left. I used them for another two years and by then it was such a Frankenpack because of the modules that I added. I randomly tested a few modules and was surprise at how much capacity they had left. I recently sold them to someone who was going to add some to an RV and others to some electric scooters.This is 7 years of reasonable use to get to 80% capacity.
Curious if you have you studied any of the manufacturers spec sheets? Typically, cells are rated for at least 2000 cycles at full C rates. EVE makes high cycle claims depending on C rates.I hope I get 1000 out of it in the end
One of the factors that can create warming is high C rate charges or discharges.cell warming up too much seems to be a factor in early cell degradation
I resemble that comment about shelf age but I do try to stay active and not spend much time on the shelf. I hope to outlast my batteries.I think most folks do baby your batteries and I’m struck that most folks are not using their batteries to the max to save money and let them slowly die from shelf age.
I happen to work with laboratory tools and proper calibrated tools are very important. And after all checking was done all necessary terminals and connection inspected it goes through cycle discharge and charge while continously recording data on individual cells resistance and voltage with total pack voltage and resistance. And for residential use this was usually in 60% of max A bms is designed for if mosfet. Residential laboratory test are always done at 75°F.On EV battery packs there are different types of laboratory tests that include various different temperatures.@Go2Guy - I hate to speak for @Steve_S (he does it pretty well himself) but I think the three main points he made - if I were to reduce them to bullet points - are:
I'm sure if I didn't get that right Steve will correct me.
- Temperature matters, because colder cells will accept current (absorb energy) slower than warmer ones. This can be important when you have more than one parallel battery being charged.
- With this chemistry, millivolts matter. In the case of AGMs or any other lead acid, you can get things to the nearest 1/10th of a volt and it's probably OK. Not so much with LiFePO4.
- Recognize that there are voltage drops throughout your system, even with large wires. Because of #2 (millivolts matter), you need to know and account for those drops from your SCC and Inverter/Charger to your battery at different charge currents and as the charge cycle finishes.
Mining for all the metal ingredients that make up all kinds of batteries is harmful to the environment as well.it’s not a drag race , keeping your refrigerator or water pump on without resorting to a generator is ideal and you want to use a gas generator to save cycles on your batteries.. it’s about surviving and being independent from using gasoline which is harmful to our environment. Yes you will be saving the disposable batteries in the long term if life cycling the batteries while doing nothing is your plan.
I said 1000 cycles because of the constant charging of 3.65 volts per battery. I believe even at that voltage, my lithium phosphate should last longer then that. I do drain them down to 2.7 volts and they will last for many years . I think most folks do baby your batteries and I’m struck that most folks are not using their batteries to the max to save money and let them slowly die from shelf age.. well at least they still look new …
Are you running cells in parallel and how many?My cells cycle between 3.5V and 3.0V, with a 400ah pack i have regularly discharged 300ah from fully charged during a cycle.
They have never been charged when over 35°C.
They are approaching 11 years old now with no discernible difference in performance from new.
In that time i have seen many others using more aggressive parameters (especially disregarding high voltage/temps) have their batteries fail.
As for shelf life - i know of packs from 2007 that are still going - shelf life is unknown as it is untested in fractional C LiFePO4.
You can ignore the actual real life experiences of those that have been using these cells for a decade, and find out for yourself how to make a cell that should last for 15 years now last for 6 years.
