Nice! So 6000W powering 100A @ 48V = 5440W (10.3% overpanel). That’s a sweet set-up.Victron 250/100.
$600 came from $736 being 123% the price of the panels. I didn't consider additional controllers.
Something to consider is paralleling more panels on the same controller. A 2S4P array would only suffer in the individual string being shaded even on the same controller.
My shading situation is peculiar and greatly compounded by my choice of half-cut panels.
The rules change with half-cut panels because they can put out 50% Imp @ 100% Vmp and a Series string has no way to improve upon that through bypass diodes so the entire string runs @ 50%.
I have a specific set of 4 consecutive panels which will be shaded only on their lower-halves for a good hour late in the morning and the only way I can capture that energy is to either string them in parallel or within their own individual string (either 4S1P or 2S2P).
And I’ve got another 3-4 panels that will be shaded vertically and I shade 1/3rd at a time, so a 3S or 4S string would be best for them.
And the final two panels are a mess and will suffer from half-shade, full-shade, and partial shade at various points throughout the morning, so just connecting them in parallel will probably work best (with half-cut panels).
I’m not sure optimizing output by planning for the best string configuration on a sun-array basis is worth the trouble, but since we’re talking about trying to save 50% to 67% of the 40% of full daily production that would otherwise be lost with a full-series or full-parallel string, my gut tells me it’s an effort worth making.
Yes, if I want the option to go to a 24V battery, I need SCCs Abe to handle at least 120V or 150V. That’s my plan.Keeping your array to a controller capable of 150V would help with the budget. 200 and 250V units carry a premium. I believe a 48V system coupled with paralleling within the array can accomplish the same results as multiple SCC.
But I may spring a bit more for one 170V+ MPPT if I decide I want to capture some of the energy on those 3 vertically-shaded panels as the shadow from the tree slowly shifts off of them...
While only half is installed (3S3P), my array will be 3S6P. I could shade 1 entire string, and the other 5 would be unaffected on the single controller. It would be no different if I had 6X 3S arrays on 6X SCC, 3X 3S2P arrays on 3X SCC, etc. I have also oriented them horizontally such that only one "string" within the panel will be impacted rather than all strings within the panel.
I’ve been considering all of those same issues as I struggle to settle on the best way to configure my 10 panels. It would be rather straightforward if they were 72-cell panels like the ones in my AC-coupled array, but half-cut panels dramatically changed the picture.
Each half-cut panel is essentially 2 half-panels connected in parallel, and this means a half-cut panel can put out Imp/2 @ Vmp (which a standard panel can never do).
If your panels are also half-cut, I’m interested to understand more about how you’ve configured them to deal with shade..,
