best overall on demand pump
e67
plains
If my pressure tank fails in the future I think I would like to go to a plastic cistern 120 ga maybe and just pump on demand to the faucets. I would do some extra plumbing to customize the set up also but basically like that....what AC on demand pump is known to be good for this...something quality...and big enough for a small home..1500 sf.
I cannot answer your question as to best, but the Shurflo brand is widely used in the RV industry and can be had for under $100. There are even cheaper knock offs but for under $100 I would be inclined to stick with the name brand. I installed one last year in a tiny home that a friend is outfitting and so far it is doing the job.
I have used Sureflos in the distant past but wouldn't mind going a bit more premium..
Another name brand is FloJet:
I have used both FloJet and Sureflo and they are more or less the same in build quality and functionality. Pretty robust.
oops...just noticed that you specifed AC power...you'll need to change the category at the xylem site to find those.
