Tradewinds63
- Jul 4, 2021
- 17
After reading the EVE test data amongst the several LF model batteries and comparing it to this chart...
It's clear that the EVE experimental test subject was the EVE LF 304. If you compare the surface areas of the various batteries, only one, the LF 304 comes to approximately 660 lbs (300Kg) total force upon its surface (55.86 in²) when using the optimal 12 PSI as the clamping force/axial force applied to the battery.
So, should someone use the 300kgf for the LF105 (surface area 40.5 in²) as an example. They would be applying 16.3 psi, which is still in the peak zone but does reduce it by a projected potential 5k cycles, from nearly 20k cycles to about 15k cycles, when compared to 12 psi. An LF 105 would produce best results not with 300 kgf but rather 220 kgf.
It's too bad EVE didn't express their unit as 2.874 N/cm² Y axial force, which is 12 psi Y axial force. Then, they'd have avoided all the confusion with respect to the applied force and been far more accurate.
