Looks like you have found a way to stay in the sweet spot!! That is awesome!OK, new figures.
Assuming 0.9mm is the travel I need to handle from 0 to 100% SOC.
I am using 5/16" x 18 TPI threads. 18 TPI is 0.056" per turn. Convert that to mm and I get 1.4224mm per turn or 1 mm = 70% of a turn. I am going to call this 2/3 of a turn since I am not a human protractor.
I retested with a total of 10 Belleville washers in series <><><><><>.
Test procedure used:
Results of doing this.
- Run nuts until finger tight (not as tight as humanly possible, just snug). Reading ~ 1 - 2 kg on cell.
- Rotate nut one full turn. Force measured = 56.8 kg:
- Rotate nut an additional 2/3 of a turn. Force measured = 90 kg
57 kg per threaded rod x 4 rods = 228 kg total = 502 lb which results in 9 PSI
90 kg per threaded rod x 4 rods = 360 kg total = 794 lb which results in 14 PSI.
The means the compression range from 0% to 100% SOC will be 9 PSI to 14 PSI (11.5 PSI +/- 2.5 PSI). I am willing to declare victory.
Here is how I am going to use this information.
- Charge all cells to 100% SOC.
- Assemble compression fixture with 4 threaded rods, 10 Belleville disc springs in series and double nuts on each threaded rod.
- Tighten all primary nuts finger tight.
- Tighten each primary nut an additional 1-2/3 turns. I suggest doing this in stages, working diagonally across the cell to ensure even tightening.
- Tighten secondary (jam) nuts against primary nuts so they won't vibrate loose. Feel free to use locktite if you want, just don't get any locktite on the Belleville disc spring washers. I am going to skip using locktite myself. If corrosion is a possibility you might want to consider lubricating the Belleville disc springs since they need to be free to move against each other.
If I understand the idea correctly, I believe HaldorEE is using one ‘strength’ if Belleville washer to handle most of the expected expansion range and then when all of those have bottomed out (gone flat), he has some ‘stronger’ Belleville washers in each stack to handle any additional expansion at increased pressure...Looks like you have found a way to stay in the sweet spot!! That is awesome!
But I can't quite tell what the graph is showing (image is too small for me to read). Is y axis pounds or kg and x axis time? If so am I correctly interpreting that you have two big plateaus at roughly 9psi and 14psi?
Your values (roughly) plotted against the A123 pressure/cycle life curve:
Correct. Y = kg, X = time.Looks like you have found a way to stay in the sweet spot!! That is awesome!
Not any more. Because of the reduced range of motion required, I am able to use just the stronger washers. I was going to create a progressive spring if needed, but if I don't have to, they why bother.If I understand the idea correctly, I believe HaldorEE is using one ‘strength’ if Belleville washer to handle most of the expected expansion range and then when all of those have bottomed out (gone flat), he has some ‘stronger’ Belleville washers in each stack to handle any additional expansion at increased pressure...
@HaldorEE I'm sure you have posted it but .... can you post a link to the washers you are using?
I think this is smart for two reasons.And I biases the curve slightly down (my center position is 11.5 PSI). I would rather be just a bit on the lighter side, than to be squeezing too hard.
ThanksMcMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
Out of curiosity, using a torque wrench, i'd love to know what torque it would take in Nm to release that nut, while you had it under 11.5PSIView attachment 34628
He is not quite thru the full range yet .... We'll see where he ends up.Average movement is what I am interested it (average of all four springs)
It is less than the 20 in-lb my 1/4" drive torque wrench is able to measure.Out of curiosity, using a torque wrench, i'd love to know what torque it would take in Nm to release that nut, while you had it under 11.5PSI
That is handy info, thanksI think that despite my torque wrench claiming it works down to 20 in-lb IT LIES!!!!
I repeated the test using 40 in-lb and got this. Which is amazingly close to the desired compression force.
That is also the appropriate force we are supposed to torque the bus screws. My head is spinning, what does it mean?
Note to self, don't use my torque wrench at 20 in-lb.
I don't know how handy or believable that is. Look at my caution post.That is handy info, thanks
I have no way of working in Psi. My torque wrench goes down to 1Nm and supposedly accurate to 4%(iirc) (it is the 'click kind' and if you go really slow, the click is clear and positive every time).Caution. The above torque/clamping force result is highly conditional (albeit a lot more repeatable than I expected).
Change any of the above conditions and your result is likely to be different. Possibly very different.
- I am using 5/16" x 18 zinc plated carbon steel bolt and nut.
- There is absolutely no compliance in my test setup (those are thick fender washers and that base is 1/2" thick mild steel).
- My threads are dry, but I have run a nut up and down the bolt many times.
