Ok, now I've had a year with a 6000xp hooked up to 4 - 100ah 12v lithium batteries and being treated as lead acid. Mostly it's been fine, but just recently I had a battery start losing capacity (now it is down to 50ah). This throws the other 3 batteries way out of balance as the problem battery goes into high voltage shutdown way before the other batteries do, and it goes into low voltage shutdown way early as well.
I've seen this universal battery balancer proposed as a solution at Watts247 but I am not totally convinced that we should be constantly balancing from high voltage to low voltage. In the above case, where one battery begins to die, simply re-balancing from high voltage to low voltage like crazy only hides the real problem.
I know that buying a 48v server rack battery with battery communications is the accepted solution, but is there any way to go with 100ah 12v batteries and get the same set-it-and-forget-it ease of use?
