Best strategy to increase my production
Vince2
Lexington, ky
So, like many others, my grid tie system was designed based on my power bills of the previous year. I build a 10k ground array with a 7.7 sma sb inverter, and passed inspection etc and been satisfied for 4-5 years, having a deficit in Jan and Feb months and a yearly production of 12-13 000 KW. Now, I switched my propane heating to mini splits, had a plug in vehicle and now also an electric truck and my production can't keep up. I expanded my array with about 5K in panels keeping the same inverter and it has increased my production by about 25 %. Because I did not change the inverter I did not have to go through another electrical inspection.
I have build a diy battery bank, 48v 380A, and have a 6 kW LF 120V inverter-charger for emergency backup, with all my 120 V breakers on a sub panel. When I checked with my power company what the typical power outage is, they told me that in past 10 years, typical outage took less than 3 hours to repair, and never more than 7 hours.
Basically the backup is more for peace of mind than a necessity.
I have the option to do time shifting, but the difference in price is only 2 or 3 cents per KW, normal rate is $.097 and reduced rate is $0.07 with $0.12 for peak rate. Don't see much benefit on going this way as the heating and cooling are all in peak time.
I probably need another 5000KW per year to break even. Any ideas about the best ways to do this?
Option1 Take the 5K panels that were added and add another 5K in panels, a new hybrid inverter and go through permitting to get it approved.
Option2 create an off grid system separate from current net metering system and bypass the permitting process. Switch manually from on grid to off grid for the evenings and nights when battery capacity is sufficient to carry the loads.
Other options?
I vote for a off grid system no permit and backup power during a outage, also can you run the mini splits solar direct then switch when solar doesn’t cut it
I would think that manual switching would get old really quickly, even aside from the potential for equipment damage due to frequent power interruptions.
We run supplemental A/C and Heating from our battery backup instead of just letting it sit there. The system is not connected to the grid. Any solar power we use means less power we buy from the PoCo.
I just realized that I can probably run all my 120v load from my battery and a 6k hybrid inverter with 5k panels continuously, with exception of extended overcast, in which case, I could switch over to the grid, and recharge the battery. I'll keep all my 240v load separate with the net metering.
I am installing a contactor to turn off/on the grid power one day, turn off at 6AM and turn on at 8PM.
Do you know it will be a concern for equipmeny damaged? Sorry it is an off topic.
No I don’t see any major damage potential, maybe some added wear and tear from thermo cycling, the biggest problem is your beer is going to be warm and resetting all those dam clocks on your appliances
