Hi, I tried the 100 incandesant light bulb, it works, but very slowly, if you want to lower your cell voltage 100x faster, use this, It lowers the voltage very quickly, and is much safer.
Simply short the two poles of your battery through this resistor, You may need to add some thick wire to make it reach, 10 gauge would be fine. You could also use car jumper leads.
As a safety test, I hold on to it, when it gets too hot to hold any longer, I disconect it from the battery. Its a $10 200W heavy duty resistor.
KKmoon RX24 200W 1ohm / 2ohm / 4ohm / 8ohm / 10ohm Aluminum Shell Resistance Metal Wirewound Wire Wound Winding Resistor Dummy Road - - Amazon.com
www.amazon.com
I use these resistors all the time to avoid sparks, anytime you connect your inverter, BMS or similar to your battery, Use this inline on the end of the wire first. Just a 1 second touch is all you need, then connect the leads as normal. The polarity is not important. No more sparks!
