probablynotbill
- Feb 21, 2021
- 2
I've been looking at the Jackery 300 primarily because of it's small form factor and bi-directional USBc PD 60w port. My most frequent use case will be just to charge my laptop and allow me to work more outside and weekender car camping trips. Could I also use that bi-directional USBc port to charge and accept charge from a secondary external 50ah or 100ah LiFePo4 battery for extended use cases?
This is an attractive use case to be able to use the tiny ultra-portable form factor of the Jackery 300 with it's 100W solar panel most of the time, but be able to connect a better battery when I need the extra storage. In all cases the 300w throughput is adequate for my needs.
Would that work? What kind of cable / charger would I need to build/purchase to charge say an SOK 100ah battery and later draw power back to the jackery using the same system?
Thanks in advance for guidance!
