duncancw
Hi,
My boat currently has a 90Watt solar system that provides power to the house battery. It's great for keeping the battery topped up in winter when she is ashore and during the summer it does keep my 12v fridge running most of the day (in sunny conditions). It's great for day sailing and the weekends but not great if we want to use the boat for an extended period as it doesn't generate enough power.
I've therefore purchased an additional 200watts of solar (2x100watt panels in serial). I've installed the panels and ran the cables to a new Victron SCC (100/20). The bit I'm having problems with is the connection between the new SCC and the house battery. The existing system is getting a bit messy and there are already 4 connections on the positive side of the house battery. At some point I would like to install an invertor so I would like to provision for this moving forward.
I've attached a diagram to illustrate my scenario. The new components in the gold box are what I've install so far but as you can see I've not attached them to anything yet. (I haven't actually wired the new solar panels into the SCC but the cables are in situ).
Should I get rid of the 6 way fuse box and install a Victron fused distribution board or is that overkill? or could I just install a positive busbar?
Any advise before I proceed any further would be greatly appreciated.
