I need to join my two 8S Modules with two 8S BMS's to power a 24V system. How do you do it and what should it produce? Fuse both positive leads separately and join positive leads to positive bus bar. Separate shunt for each module's negative lead and join to negative bus bar? 1200W solar panels, 40A Epever solar charge controller, 24V Samlex 2200W Inverter Charger, (16 ) 280Ah LifePO4 cells divided into blocks of four cell. Those are the main components. Are the copper bus bars worth the trouble or can I get by with the nickel plated bus bars that came with the batteries.
