Please help, have not found any threads on this as yet and I am new to solar
I have purchased 2 x 275 Canadian Solar panels and are looking to make my water pumps work directly from the panels.
I have 2 x Water Pumps:
Specifications:
RD-DC 12V is a submersible pump with stainless steel casing
Voltage:12V
Power:120W
Caliber:25mm(1")
Capacity:26.4US.GPM
Max Lift: 5-7M
Main applications: Water
Cable Length: 2.5M
and 2 x Canadian275w Solar panels.
Specs:
Pmax - 275w
Vmp - 31.3 V
imp - 8.80 A
Voc - 38.3 V
Isc - 9.31 A
Please what do I need to get these water pumps working from these panels. The Panels will be south facing.
I will not be having batteries as its only for day time pumping. ( for my fish pond).
What size controller would I need and should i be parallel or series?
Can I wire both pumps together or best separate with 1 panel for each
Thank you in advance for all your help and support.
Specifications:
Voltage:12V
Power:120W
Caliber:25mm(1")
Capacity:26.4US.GPM
Max Lift: 5-7M
Cable Length: 2.5M
Specs:
Pmax - 275w
Vmp - 31.3 V
imp - 8.80 A
Voc - 38.3 V
Isc - 9.31 A
