WorldwideDave
Diesel RV (motorhome). 170 Amp alternator. Also has large (8kW I think) Onan diesel generator on board.
I am adding solar to it. I have several Victron MPPTs and solar panels to use/choose from, and there is already a 2000 W inverter on the vehicle that works that I will likely replace. I will also add Cerbo GX and a Smart Shunt 500A as well.
Before I decide what equipment to put onboard, and before I decide if I am keeping the house system 12V or upgrading it to 48V, I need to know the options I have to charge the house batteries & the chassis battery.
I don't believe the A/C will run (roof mounted) without the 50A shore power. I may change this by going big battery and a quattro inverter. I might not. Unsure.
But I do need to know what the best way to charge the batteries will be.
For example, I know that using the sun to charge the house batteries is the most quiet and efficient, but not the fastest way.
I believe the large diesel generator will also charge the batteries, but not sure if that is smart vs. starting the RV's engine and using the alternator.
Some have said to buy a small portable generator that are quieter and use less fuel.
To be honest I was a bit surprised the generator used diesel and not propane, which the RV has for heat and hot water and I think the refridgerator too.
I was considering getting an Orion DC to DC charger, but won't decide on that until I know if I am going to go with 12V or do 24V or 48V. Sounds like the Orion product released in November 2024 (the XS?) does 50A but only works in a 12v/12v configuration so far. People seem to like that device, but warn it could fry my alternator if the vehicle is not moving or going up a hill or something.
Open to thoughts/suggestions. Thanks!
