I have an existing 16W ground array and am preparing to build another 16KW array next to it.
I am planning to use AWG 14 or 12 PV wire with MC4 connectors to connect to the strings, but then all the wires go into a junction box and then a 250ft conduit. Its a 1.5inch conduit. The existing array uses 7 AWG THHN (3 strings + GND) conductors running through the conduit - and I want to add another 6 conductors (3 strings). I am leaning to using THHN 14 AWG, since the conductors will be 10A max, and THHN has thinner insulation to ensure I stay within 60% usage of the conduct .
What is the best most water proof way to transition from the PV to THHN wire.
The old array used 2 to 1 screw in connectors since its was 6 strings going down to 3.
This year the junction box and 3/4 of my array ended up underwater due to heavy rain - so I should plan for some possible submersion for periods of a couple of days.
I am located in California - Bay area. Welcome any recommendations. Thanks.
