Aakelley
- Feb 3, 2022
- 140
I purchased the bundle that Signature Solar was selling over the holidays. It has a Growatt 3000 24V, 2 of their EG4 24v 200 AH server rack batteries and 10x 265W panels. I purchased it to add solar to my skoolie. I‘ve been doing some test assemblies in my workshop before the real install and reading / watching as much as I can on the inverter and the batteries. This forum has been a great resource - thank you all!
I will probably have a few questions as I go, but here is the first: since my skoolie is setup for 30 Amp Service and the generator I bring along is only a 3500 watt predator, would it make more sense to wire the Growatt and shore power into a transfer switch and then into panel rather than having power run through the Growatt and then into the panel? I know I would be bypassing the shore power charger in the Growatt in this case, but given the power constraints (yes, I could upgrade the shore power service to 50 amp and buy a bigger generator - question is in the context of what I have in place) it seems to me it might be a better way to go.
I do have a seperate battery charger from Signature Solar so if I was on shore power / generator and wanted to charge the battery / wasn’t using much other power I could.
