Looking deeper at this.....Best Sun is a reseller of this unit, Fution as a company cannot be found by google. The manual is very inaccurate, states that my unit has 32 cells but I count only 16. My unit looks like the 3 kw unit on Amazon but the label does say 5kw, 10240 a.h. Capacity. Amazon’s pictures show the cover with the screws for the front panel inserted through the front but my unit has screws from the sides, as shown in the Amazon photos for the 1 and 3 kw units but they are 12 volt and 24 volt. This could be a revision A vs revision B situation. The documentation is horrible. It is not a purpose design unit as the inverter/charger has settings for flooded lead acid, sealed, and user defined. I am sure that this unit is assembled from stock items, when I further disassemble it I will know more. The inverter/charger is a separate unit with its own chassis which is installed within the outer casing, but with the outer front cover not installed. I have seen this inverter/charger before but with its own front cover installed on it with the lcd display. The instruction manual does indicate that the battery can be charged by the line input and solar while simultaneously outputting power from the inverter. I do not see how that is possible as in every case that I have seen a inverter/charger can do only one at a time, not both as they share the components. There is only one large torroid transformer so the manual is wrong or something. As usual the manual is first dictated in Mandarin to a Greek fellow then to a Italian then into English or something as much is lost in the translation. I absolutely cannot recommend this unit to any average user.
I have not powered it up here but have seen it powered it up at its original installation. It was functioning, charging the battery and did automatically change to inverter mode when input power was shut off. I will be mounting it on my solar wall as soon as conveniently possible and will post more about this unit as I use it.
I am using an Apple iPad with its appleautobutchermyspelling which cannot spell technical words but can remember appleautobutchermyspelling! LOL!
If you are a typical user I just can’t recommend this unit, just not supported. I will probably only use the batteries and BMS as I have much better MPPT controllers and inverters than in this unit. It came with only one page installation guide, I can’t call that a manual , but I did find a link for the manual which brought me to your forum. I’m very active on NAWS and MidNite forums. Sometimes on Solar Panel Talk and others. When I figure out how to post photos I will , if I can’t post photos here they will be on NAWS.
