marex
Canadian Off-Grid Chalet
- Sep 26, 2021
- 20
Last summer I purchased 16 CALB 200Ah cells from OYE Store that were rated at 200Ah and listed as Grade A. But in the fine print specs you can read min capacity 180-190Ah. I used that to set up a 48V Growatt system in my remote cabin and did a quick top balance and installed everything. I'm not getting at all what I was expecting.
In January 2022 I purchased 8 cells from the same store with a cell capacity tester and I was getting 184 to 206Ah capacity. Cells are not matched at all by this supplier and I even wonder if they are not Grade B because to me a Grade A cell should output at least the advertised capacity. I'm loosing +-15% in capacity, which is an indication of maybe used cells and in the end my bank is limited by the least capacity cell.
Still more tests to do as I purchased a JK BMS (2A active balancer) to compare with a Daly one (passive balancer) and see if I can get better capacity of the whole pack. Once I can get my cabin's cells back home in the spring I will test all 16 cells and hopefully be able to get 16 similar ones out of the 24!
Many vendors on AliExpress will not even let you write feedback but they show some and oddly enough they are all 4+ stars!
Next time I will buy only from a US supplier that indicates that the minimum capacity is the advertized one and will let him know that each cell will be tested upon reception.
