Zwy
Emperor Of Solar
I can add onto the wings, welding those on would not be a problem and I can even weld extensions on the aluminum Iron Ridge.
After installing the 5 high array, I would not have a problem with one that high again. I found that array is easier to tilt up and down as the balance is better with 5 high. It uses 8 inch SCH40 poles compared to the 6 inch SCH80 and I think the 8 inch SCH40 is stronger. At full tilt I set this up for 5 feet of ground clearance but the next array can be lower, 3 or 4 feet as it will be in the yard without any traffic or snow removal needed around it.
I'm looking to make it 5 high and 2 or 3 wide depending on the panels. It is a single pole mount so twist will be a concern. 15 panels makes nice 7S and 8S strings so VOC isn't a problem. 10 panels makes either 10S or a pair of 5S. I can't use the 4 MPPT's in the LV6548's with either setup though and would have to use smaller series and probably parallel some strings.
