LarryC
Larry N7LUF
I have been laid up and just got it installed after a year.
The video you said 23.5 volts be good for cutoff.
At 75 yrs I been in poor health and just could not get the work done installing it.
I changed program 5 to user and changed program 29 it to 23.5, but did not touch the other setting.
Should program 26 and 27 be change from default?
26 Bulk charging voltage (C.V voltage) default setting: 28.2V If self-defined is selected in program 5, this program can be set up. Setting range is from 24.0V to 29.2V. Increment of each click is 0.1V.
27 Floating charging voltage default setting: 27.0V If self-defined is selected in program 5, this program can be set up. Setting range is from 24.0V to 29.2V. Increment of each click is 0.1V.
29 Low DC cut-off voltage default setting: 21.0V If self-defined is selected in program 5, this program can be set up. Setting range is from 20.0V to 24.0V. Increment of each click is 0.1V. Low DC cut-off voltage will be fixed to setting value no matter what percentage of load is connected
