That should work just fine. When they are in Constant Current mode, they will each supply their set current and they should add up nicely. When they hit the Constant Voltage point, any imbalance might cause one to take more of the load, but it will still never take more than the CC setting, so I don't think it will be a problem. If the voltage is off too much, you can balance each one into a small load and check them with a meter. If one has to be set 0.02 volts higher to get the same output, it is no big deal. For $30 it seems like a great little test power supply.
