Hi guys, I bought this:
to replace a failing battery on a ups.
Can any one advice a bulk and float voltage for these cells? Does anyone have any experience with them?
I've asked big battery for these details, via phone and email, and contact edward is sick, and I'm stuck and need to this battery up and running.
The bsm specification given from big battery has no value for temperature protect. Any one know if the bms has adjustible parameters?
Below is the information on the BMS below:
Hope this helps!
Edward Bonilla | Business Development
48V Li-ion Power Pack - BigBattery.com
Electrical Specifications Voltage: 48V (G1) Capacity: 6kWh (G2) Capacity: 8kWh Configuration: 7S4P BMS Specifications Continuous Charge: 4/60A Peak Discharge: 4/120A Charging: 4/45A Fuse: 4/80A Display Battery Health & Voltage Meter Connectivity Anderson Quick Connect SB50 Physical...
bigbattery.com
Discharge | Continuous Discharging Current | 60 A |
Instantaneous Discharge Current | 120 A | |
Charge | Charging Voltage | 58.8 V |
Charging Current | 45 A | |
Overcharge Protect | Over-charge Detect | 4.28±0.05 V |
Protect Delay | 100 mS | |
Over-charge release | 4.08±0.05 V | |
Balance | Detect Voltage | 4.2±0.025 V |
Release Voltage | 4.2±0.05 V | |
Balance Current | 60±5 mA | |
Over-discharge Protect | Over-discharge Detect | 2.55±0.08 V |
Over-discharge Detect delay | 50 mS | |
Release Voltage | 2.9±0.1 V | |
Over-current Protect | Detect Voltage | 150 mV |
Detect Delay | 15 mS | |
Current Detect | 130±10 A | |
Release Condition | Cut Load | |
Short-circuit Protect | Protect Condition | Cut Load |
Detect Delay | 200 uS | |
Temperature Protect | Temperature Protect | / ℃ |
Resistance | Inner | ≤15 mΩ |
Self-Consumption | Working Current | ≤60 uA |
Sleep Current (when Over-discharge) | ≤10 uA | |
Working Temperature | Range | -30/+80 ℃ |
Hope this helps!
