Hi all! So I'm planning a ~21kw ground array and looking at some of the new Trina 650-700W panels, (Imp ~18.5A) and I have a question... (Availability & delivery issues aside!)
Where do you get suitable MPPT/inverters for these things?
Originally I was looking at Victron but they all seem to have max solar input currents of around 13A. I see some EG4s with 18V input currents (Ex: EG4 6000XP), which I guess should be okay... the 620W Trinas put out 15A so the EG4s should be good enough there...
But even then, if I use the Victron "what do I need?" website and pick more "normal" 420W panels, I can only put 3-5 in a string before they don't have any recommended products.
So...
Q1: Am I missing something? I know at least some of y'all have 20kw+ arrays, is there a reason why I can't find an MPPT with that kind of input current?
RELATED: So if I look at the EG4 6000XP as the "biggest" MPPT I can find, the relevant info seems to be
Max usable input current - 17A... MPPT Operating range 120-385VDC ... Nominal MPPT Voltage 320VDC ... Maximum utilized solar power 8000W. (4000W per MPPT).
So (with the 620W panels @ 15A x 41.4V ) that would be two strings of 6 (3726W x2 = 7452W). Or with 445W panels (15.1A x 29.5V), two strings of 9 for 8010W total.
Q2: Both of the above examples math out to well under 320VDC (6 x 41.4 = 248.4V) & (9 x 29.5 = 265.5V). Am I better served by finding panels that will string out to get me as close to 320V as possible? (Or, finding an inverter with nominal ~250VDC operating?) Or is that not a big deal?
Q3: The next question becomes "huge buck converter time." Because if the ground array is going to be some distance from the house then I'll want to push the voltage as high as possible to minimize line losses... Both of the Trina panels have max voltages of 1500, so in theory I could put all 33 of the 620W panels in series for 1242VDC before the underground run to the house... but then I need to drop it to ~450VDC safely somehow. Guess I could put three inverters in parallel but if one shuts down for some reason the other two would spike to over 600V, pesumably not good.
Thoughts on this, anyone? I'd be most grateful.
So...
