I have purchased 4 - 12v 170AH BigBatteries and have them connected in series (24v) / parallel.
They don't seem to keep the balance between 12v batteries. When charging, one battery will hit ~13.6v and stop charging and the rest of the charge will go into the other battery at 15.3v (13.6+15.3=28.9v).
I don't want to break the warranty seal to check each of the cells. I sent one back to big battery and their shipping department said it was fine, but they didn't test it as a series configuration...
Just a follow up on my original post.
I am still waiting to get the 12v battery I returned to BigBattery back to me. It was returned 1 month ago, just fyi if anyone is curious on the warranty's timeline.
They claim there is no issue with the battery, but they would not test it in series with another battery. Discussing it with manager, stated the series issues didn't matter as long as the single battery performed correctly. He wasn't willing to acknowledge their could be issues with each bms not being able to communicate with the other causing the balancing issues.
When I get it back, I will go through each cell and check for balance and then balance to the other battery in the series.
They were not willing to swap/trade for 24v batteries that I could run in parallel.
If I continue to have balance issues while in series, I may purchase the 24v 8s BMS here on Wills site and use the one BMS to handle two batteries.
I'll do another follow up.
