I posted about this under All in Ones but I'm now leaning towards it being a battery issue.
My LV2424 Hybrid is connected to a 24v bigbattery HWK and a wall outlet with grid feedback disabled. The low voltage cutoff was set to 23.5V and the " battery stop discharging when grid is available" setting was set to 24v. Solar was set to be the only charging source for the battery so as to not waste power cycling grid power through the battery. The goal hear was to use up all the solar power generated by directing it to the loads first and then to the battery and using the grid when those were insufficient.
I had about 500 watts of consistent load connected to it (just a router and a small server) so definitely not pushing any limits.
This morning I found the whole system turned off. The loads appear to have gone offline around 4 AM. When I went to bed the LED panel on the LV2424 suggested the loads were running off AC power only and the voltage was around 24v which is what I would have expected at that time.
The LED voltage readout on the bigbattery is off (despite the power button being in the on position) but a volt meter across the disconnected battery contacts reads 23.5v so it's not so dead as that.
While the LV2424 is not powering on at all despite being connected to both PV and AC input my volt meter reads 26.1 across the battery lugs when the AC is disconnected and 27 When the AC is connected.
This behavior makes me think something internal to the battery has failed in some way although that's a very middling voltage so I can't think of what.
Update: bigbattery support confirmed that this was unusual behavior. They walked me through "resetting the BMS" by removing the top cover and unplugging it for 30 seconds. It still doesn't power on but now when I test the voltage it reads 1.735v (???). I have no idea what is going on with this thing.
